Thread: Water drill
    Sep 2013
    TERBPA's Tools
    Water drill
    If any of you have had the displeasure of trying to dig through caliche, then you understand why I made this. It's just a 36" pipe section with a brass tip (1/4" hole) on one end and a hose fitting with ball valve on the other end. I can push down a full 24" in caliche with this (regular water pressure) in about 30 seconds or so. Larger holes, I just do a series of holes in close proximity, use a caliche bar to break up between the holes, and a post hole digger to clean it out. Messy as a two year old in a room full of open paint cans, but very effective.
  2. The Following User Says Thank You to TERBPA For This Useful Post:
    kbalch (Sep 12, 2013)
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Thanks TERBPA! I've added your Water Drill to our Miscellaneous category, as well as to your builder page: TERBPA's Homemade Tools. Your receipt:
