Homemade Pipe Alignment and Welding Clamp
EclecticNeophyte on homemadetools.net
Homemade pipe alignment and welding clamp adapted from a standard C-clamp with the addition of two lengths of steel angle. In use, the tool is positioned to span the gap between two sections of pipe, thereby aligning them for welding.
- Making an ice boat - GIF by BuffaloJohn on 2025-01-06 15:20:12
- Hydraulic stilts - GIF by BuffaloJohn on 2025-01-06 15:17:56
- Milling machine - video by SteelCraft on 2025-01-06 15:11:07
- 3 point (scribing) centre punch by Saltfever on 2025-01-06 14:50:47
- High-pressure water jet for unclogging pipes - GIF by Karl_H on 2025-01-06 14:19:39
- Makita hole puncher - GIF by BuffaloJohn on 2025-01-06 14:07:11
- Breaking an I-beam - GIF by Karl_H on 2025-01-06 14:07:10
- When someone asks you: "Is it level?" - GIF by Karl_H on 2025-01-06 14:01:04
- Crane building itself - video by Karl_H on 2025-01-06 13:48:12
- Heat activated Christmas card - GIF by Karl_H on 2025-01-06 13:38:56
DIY Pipe Alignment and Welding Clamp - comment on how to build a Pipe Alignment and Welding Clamp - 0 comments
Be the first to comment on this DIY Pipe Alignment and Welding Clamp, or add details on how to make a Pipe Alignment and Welding Clamp! Click the "add comment" button above to comment.
