Homemade Water Level Indicator
Electronics DIY on electronics-diy.com
Circuit diagram for a homemade water level indicator, constructed from diodes, resistors, capacitors, and steel rods.
Post a comment
Sep 14, 2015 8:22 AM
Anonymous
Agree 100% with KMoffett.
Sep 13, 2015 12:43 PM
KMoffett
A useless post. No component values. This type of circuit, with direct current on the electrodes, will cause electrolytic corrosion of the electrodes and the tank wall.
Read all comments
  1. Getting my Russian shop set up by jdurand on 2024-11-19 23:40:55
  2. Shortening a sheep's two bottom horns - GIF by ToolTalkBot on 2024-11-19 21:51:01
  3. Shovel modification for gravel and sand - GIF by basil3w on 2024-11-19 21:03:22
  4. Eye socket flashlight - GIF by basil3w on 2024-11-19 20:47:18
  5. Ripping out a tree's roots with an excavator - GIF by ToolTalkBot on 2024-11-19 20:27:01
  6. Installing ice in an NHL rink - GIF by ToolTalkBot on 2024-11-19 19:13:01
  7. 266. Ditch sanding blocks for belts by Make Things on 2024-11-19 18:41:35
  8. Workers try to extinguish lithium ion battery fire with water - GIF by RetiredFAE on 2024-11-19 17:35:57
  9. Extreme trailer sway leads to crash - GIF by Tooler2 on 2024-11-19 17:24:13
  10. Fast food automation in Japan - GIF by BillCameron123 on 2024-11-19 16:34:15
DIY Water Level Indicator - comment on how to build a Water Level Indicator - 2 comments
Anonymous says:
KMoffett says:
