Homemade Spring Tension Sheetmetal Brake
brucer on jalopyjournal.com
Homemade sheetmetal brake featuring a spring-loaded clamp plate.
Post a comment
Oct 01, 2013 10:57 AM
daveward
Good story...yep...a sheet metal break is a common homemade tool...looks simple, but takes a bit of fiddling to be perfect.
Read all comments
  1. Portable X-ray machine - GIF by ToolTalkBot on 2025-01-06 15:42:02
  2. Making an ice boat - GIF by BuffaloJohn on 2025-01-06 15:20:12
  3. Hydraulic stilts - GIF by BuffaloJohn on 2025-01-06 15:17:56
  4. Milling machine - video by SteelCraft on 2025-01-06 15:11:07
  5. 3 point (scribing) centre punch by Saltfever on 2025-01-06 14:50:47
  6. High-pressure water jet for unclogging pipes - GIF by Karl_H on 2025-01-06 14:19:39
  7. Makita hole puncher - GIF by BuffaloJohn on 2025-01-06 14:07:11
  8. Breaking an I-beam - GIF by Karl_H on 2025-01-06 14:07:10
  9. When someone asks you: "Is it level?" - GIF by Karl_H on 2025-01-06 14:01:04
  10. Crane building itself - video by Karl_H on 2025-01-06 13:48:12
DIY Spring Tension Sheetmetal Brake - comment on how to build a Spring Tension Sheetmetal Brake - 1 comments
daveward says:
