Homemade Emissions Sensor Removal Tool
redsilo on homemadetools.net
Homemade emissions sensor removal tool adapted from a 1/2" drive 7/8" 12-pt socket. Socket was cut in half and welded together to facilitate access in the restricted area toward the rear of the passenger side manifold on a 5.0 liter Crown Victoria engine.
- tool is used to remove a car tire by bandit000 on 2025-01-02 19:37:30
- Drain clearing machine - GIF by ToolTalkBot on 2025-01-02 19:13:01
- Concrete staircase cutting saw - GIF by Frank S on 2025-01-02 18:49:06
- High-pressure water jet for unclogging pipes - GIF by hemmjo on 2025-01-02 17:52:08
- Corner clamps by geo098760 on 2025-01-02 16:56:58
- Making a V-Block on a Rotary Table by Improvised DIY on 2025-01-02 16:24:46
- End Mill Sharpening Fixture with plans by jjr2001 on 2025-01-02 16:19:39
- 3D Welders Square Clamp by Liquidhandwash on 2025-01-02 16:04:48
- Testing for leaks under tile floor - GIF by ToolTalkBot on 2025-01-02 15:42:01
- Laser gun - GIF by sossol on 2025-01-02 15:29:42
DIY Emissions Sensor Removal Tool - comment on how to build a Emissions Sensor Removal Tool - 0 comments
Be the first to comment on this DIY Emissions Sensor Removal Tool, or add details on how to make a Emissions Sensor Removal Tool! Click the "add comment" button above to comment.
