Homemade Electrical Plug Removal Tool
67Mustang Al. on hotrodders.com
Homemade electrical plug removal tool fashioned from a small piece of lathe-turned metal with a 2mm hole drilled through the center. Connector pins are removed by pushing the hollow tool over the pins.
Sep 22, 2013 4:33 PM
DIYer
Neat! I guess the tool you need for these terminals depends on their shape. Blade-style terminals could do with a thin flat screwdriver.
- Splitting a large boulder with pegs - GIF by gcrimi2005 on 2025-01-20 08:16:07
- How hip replacement surgery is done - GIF by ToolTalkBot on 2025-01-20 08:14:02
- Trick - How to use Isolierband in a narrow place by albertq on 2025-01-20 07:32:31
- Making a coin bracelet - GIF by Hans Pearson on 2025-01-20 07:18:33
- Simple roller bender - video by albertq on 2025-01-20 06:57:48
- Ultra short form tapping head gets its first trials on mill and lathe. by albertq on 2025-01-20 06:48:03
- Giant mobile water pump - GIF by ironwrx on 2025-01-20 06:32:17
- Sandstorm stabilization structure - GIF by ToolTalkBot on 2025-01-20 06:07:01
- I combined two engines into one opposed-piston engine, and it worked. by IntheGroove on 2025-01-20 05:11:38
- Wheel spoking and truing. by DIYer on 2025-01-20 02:44:39
DIY Electrical Plug Removal Tool - comment on how to build a Electrical Plug Removal Tool - 1 comments
DIYer says:
