Homemade Clutch Hub Locking Tool
inxs on xs650.com
Homemade motorcycle clutch hub locking tool fashioned from three surplus clutch plates sandwiched between two steel rings and secured by four nut and bolt pairs.
- tool is used to remove a car tire by bandit000 on 2025-01-02 19:37:30
- Drain clearing machine - GIF by ToolTalkBot on 2025-01-02 19:13:01
- Concrete staircase cutting saw - GIF by Frank S on 2025-01-02 18:49:06
- High-pressure water jet for unclogging pipes - GIF by hemmjo on 2025-01-02 17:52:08
- Corner clamps by geo098760 on 2025-01-02 16:56:58
- Making a V-Block on a Rotary Table by Improvised DIY on 2025-01-02 16:24:46
- End Mill Sharpening Fixture with plans by jjr2001 on 2025-01-02 16:19:39
- 3D Welders Square Clamp by Liquidhandwash on 2025-01-02 16:04:48
- Testing for leaks under tile floor - GIF by ToolTalkBot on 2025-01-02 15:42:01
- Laser gun - GIF by sossol on 2025-01-02 15:29:42
DIY Clutch Hub Locking Tool - comment on how to build a Clutch Hub Locking Tool - 0 comments
Be the first to comment on this DIY Clutch Hub Locking Tool, or add details on how to make a Clutch Hub Locking Tool! Click the "add comment" button above to comment.
