Results 1 to 6 of 6
Thread: Yet another CNC Compatible Electronic Edge Finder
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    This design is three times more sensitive than past efforts yet costs about the same. It uses analog circuit design techniques to detect any drop in resistance of more than 0.124 ohms.
    If you are interested, please, click here.
    Thanks,
    Rick
    Download plans for touch probes.
    Rick
  2. The Following 11 Users Say Thank You to rgsparber For This Useful Post:
    baja (Jun 16, 2024), bruce.desertrat (May 6, 2022), DIYer (Apr 30, 2022), emu roo (Jun 12, 2024), Inner (Apr 29, 2022), Jon (May 5, 2022), nova_robotics (Apr 29, 2022), Ralphxyz (May 15, 2024), Sleykin (Apr 30, 2022), swk (Apr 30, 2022), Tonyg (Apr 30, 2022)
    Thanks rgsparber! We've added your Electronic Edge Finder to our Measuring and Marking category,
    Rick,
    This is not a criticism because if something works, it works. However, there is an easier way for those less skilled with a soldering iron. That is by using an Arduino style micro. The Uno is only 10 bit IIRC but I think that the 3.3v versions are 12 bit as is the ESP32 which I now use. That means that you have an analogue input resolution of 3.3/4096 = 0.00081 v. Let's plan on the same 100 mA that you use, then for a change in resistance of 0.124 ohms we get a voltage change of 11 mV (for your 4 ohm limit) and 14 mV (at your 0.3 ohm limit) which is over 13 and 16 times the resolution. So a 12 bit ADC input is more than capable of detecting a 0.124 ohm change, even a 10 bit conversion would work but I'd prefer the extra safety margin of 12 bit. The code for the micro would only require a few lines.
    Read value.
    if detect change ->
    start output pulse
    fire led
    wait pulse duration
    end output pulse
    kill led
    repeat loop.
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    Rick,
    Read value.
    if detect change ->
    start output pulse
    fire led
    wait pulse duration
    end output pulse
    kill led
    repeat loop.
    Tony,
    Great minds think alike ;-)
    "Easier" depends on the reader. I have already developed an Arduino based EEF and a few readers didn't like it because they only knew how to do circuits. As you can see in my article, there is a bit more to it than a simple conversion. It was also fun because I did it with an ATTiny-85 and a much smaller test current.
    Rick
    Rick
  6. The Following 3 Users Say Thank You to rgsparber For This Useful Post:
    Ralphxyz (May 6, 2022), Sleykin (May 6, 2022), tonyfoale (May 3, 2022)
    Congratulations rgsparber - your Electronic Edge Finder is the Homemade Tool of the Week!
    It has been interesting watching this project evolve over the years, and it keeps getting better.
    Bender by Kwandotechnic
    Shooting Board by Dr.Al
    Horizontal Bandsaw Stand by micksworkshop
    Hand Sander by orioncons36
    Post Extractor by Unisawyer
    Mini Mill Stop Block by JKeetonKnives
    Woodturning Tool by Make Things
    Parallels by Rustinox
    Toolmaker's Clamp by Improvised DIY
    Disc Grinder by Mr.DK DIY
    Belt Sander Contact Wheels by Mazay
    rgsparber - you'll be receiving a $25 online gift card, in your choice of Amazon, PayPal, or bitcoin. Please PM me your current email address and gift card choice and I'll get it sent over right away.
    This is your 9th Homemade Tool of the Week. Here are all of your Homemade Tool of the Week winning tools. Congrats again
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    I have written a comparison between this Analog Electronic Edge Finder and my Software-Defined Edge Finder. The bottom line is that the SDEF costs less and is more reliable but is harder to build if you are unfamiliar with the Arduino environment.
    Rick
    Rick
