Thread: Wrapping large storage tanks - GIFs
    Wrapping large storage tanks.
    Roll wrapping machine - GIF
    Spool wrapping machine - GIF
    Cable winding and wrapping machine - GIF
    Cable wrapping tool - GIF
    Transformer wrapping machines - GIFs
    nova_robotics (Jan 25, 2023), Scotty1 (Jan 25, 2023)
    Mar 2018
    Do they apply the resin in another step? Usually these winding operations (on a much smaller scale) run the fiberglass filament through a resin bath, squeegee off the excess and then apply to a mandrel to form the cylinder. I'd love to see how they extract the form from a cylinder that size!
    "This country was founded by a bunch of slave owners that told us all men are created equal..." - George Carlin
    A small shop I worked for built CNC automated winding machines. Largest maybe 10' diameter cylinders about 20' in length. There are limitless combinations of each, depending on how the vessel will be transported and used.
    Many were gas bottle and stock tank sizes, none of those use a mandrel, beside a threaded neck or spout.
    It's like meshing your fingers, two or more pairs of roving wet with resin (countering filaments) are pulled onto the rotating neck, program creates the blend into vessel body, and rounded base. It's quite fast; centrifugal force and rapid traverse of filament being fed holds it self up; usually. Inside isn't straight walled like a pill bottle, the taper supports extending outside perimeter.
    Similar to watching a potter use a wheel, raising a clay vase. That was inspiration for filament winding. Like the video of winding rebar reinforced concrete piers, larger containers almost the same, but a carriage pulls material and does the bias pattern. I expect examples like above start on a large ring, thicker to contain weight, and vertical frame of rod.
