Thread: World's largest bulldozer ever built
    Built in the early 1980's and never delivered.
    https://www.constructionequipmentgui...orgrader/40810
  2. The Following 6 Users Say Thank You to Frank S For This Useful Post:
    clydeman (May 27, 2023), Jon (May 23, 2023), nova_robotics (May 23, 2023), Ralphxyz (May 23, 2023), Rangi (May 25, 2023), Scotty1 (May 23, 2023)
    hemmjo's Tools
    So many thoughts as I skipped through the video, #1 was turn off the music, #2 I wished U-Tube had a 4x speed option. #3, I guess we have learned a lot about building equipment since the '80's.
    some random observations as I skipped through.
    31:31, hope they remember to remove those cables holding the track slack up off the ground before the move it.
    32:06, OOPS, it won't start, have to pump up that primer.
    34:19, Whew, it finally started, that would have been embarrassing!!
    34:37, they did remove the track cable.
    36:06 they had more axles hidden under that trailer, they would have to steer with that many.
    36:37, no wood under the tracks. Those grousers are going to leave a mark!!
    37:10, Ah it is a gravel pad..
    38:01, enter the "suits" for photos!!!
    38:40, begin final assembly of power plant, install exhaust pipe. Just push it on, then give it a wiggle to make sure is it tight. yep that will hold it!!!
    39:17, "Rollin some coal". better get those guys off the tracks!!!
    39:39, WHAT? No back up alarm!!! Call the OSHA guys..
    48:31, if we hide is under this bridge, maybe no one will see it?
    52:54 wonder if they ever put the blade on the machine and pushed dirt with it?
    53:25 its "New Home" I wonder if it is still sitting there?
    hemmjo; yes it was used on 1 job in Italy. Even though it was never delivered to the intended buyer due to circumstances. it was taken to a job site and used but it was too expensive to be transported from job site to job site. It would have been a good choice to send it to a large mine for long term use but stuff happens.
