New plans added on 11/22: Click here for 2,593 plans for homemade tools.
mwmkravchenko (Apr 11, 2023), WmRMeyers (Apr 8, 2023)
I think it was mostly the gale force wind! Did you see how much he was blowing up top? Add that to the extra area of the A/C unit and the crappy ladder setup, and he's wondering if the boss is gonna take the A/C out of his paycheck. And the ladder bonked him on the head, too, just to pound home the point.
For topical application, only. Not to be taken internally or used in com-
bination with other drugs or alcohol, except as directed by your shaman.
Do not operate heavy equipment, unless you actually know how to.
mwmkravchenko (Apr 11, 2023), schuylergrace (Apr 9, 2023)
Derailing the thread a bit, but I have a question about this. I had to solve this problem (working drywall above a stairwell) before and my solution was to put an extension ladder from the stairs to the adjacent wall and place a 2x12 on the ladder for improvised scaffolding. Is there a better way to do this? That felt super sketchy at the time.
From the picture it looks like those are open steps so that wouldn't have worked at all, unless they made a special box to hold the ladder in place.
a] There are rare occurrences of derailing a thread, we all have entirely different circumstances and resources, continually.
b] If it felt sketchy, it was. If it felt super sketchy, you are lucky.
c] That you were able to scale it, work and finish job, is good.
d] That you're open to remedies is best of all.
I see painters and drywallers use ladder jacks all the time, but the ladders are parallel. Stuck into the steps, probably equal strength, I'd add cleats to the back side of plank to prevent shifting. Mudding joints, standing on planks is one thing. Raising sheets of material off to side or overhead, no way. Likely end up like guy with the AC unit.
In pic I posted, the decent solution would lag a 2x6+ 'rail' to floor where the ladder feet are blocked from moving. It could be entire length of landing, for the sheet joints and corner.
ductape (Apr 11, 2023), Elizabeth Greene (Apr 11, 2023)
