Results 1 to 4 of 4
Thread: Wooden jig for stamping/punching letters straight
    Supporting Member dekeros's Avatar
    Oct 2018
    Sweden
    dekeros's Tools
    I made this simple jig in wood for making it easier to stamp/punch letters straight and with consistent spacing. I'm planning on doing a set of T-shaped spacers to make the space between the letters smaller (kerning) some other time for this.
    Also thinking of making this in clear acrylic plastic to make it easier to set the placement, but for me this wooden jig works fine :-)
    I make things, jigs and tools on my small YouTube channel. Mostly woodworking and DIY related.
    Check it out here : https://www.youtube.com/channel/UCiz...EOqWDZu501V0Ug
    Or you can find me on other places here : https://linktr.ee/dekeros
  2. The Following 23 Users Say Thank You to dekeros For This Useful Post:
    baja (Nov 1, 2018), blkadder (Nov 3, 2020), bruce.desertrat (Oct 31, 2018), chainsawd (Dec 26, 2022), CookieCrunch (Oct 31, 2018), Corm (Nov 5, 2018), Home-PC (Nov 4, 2020), Jon (Oct 31, 2018), LMMasterMariner (Oct 31, 2018), Moby Duck (Nov 5, 2018), mr mikey (May 17, 2023), natie123 (Nov 1, 2018), NYNorm1 (May 19, 2023), PJs (Nov 1, 2018), Ralphxyz (Jan 17, 2024), Rangi (Oct 31, 2018), rlm98253 (Oct 31, 2018), Seedtick (Oct 31, 2018), sossol (Nov 3, 2020), sparky42 (Nov 4, 2020), uv8452 (Mar 29, 2023), WmRMeyers (Mar 29, 2023), zarembak (Oct 31, 2018)
    Thanks dekeros! We've added your Letter Stamping Jig to our Measuring and Marking category,
    as well as to your builder page: dekeros's Homemade Tools. Your receipt:
    Supporting Member blkadder's Avatar
    May 2012
    Florida, USA
    I like it. Seems like an easy way to make sure the stamps are straight. I made up one of these using angle iron to stamp info onto STEN gun receivers.
    Ron
    ...Semper Fidelis...
    Oct 2019
    Germany
    uv8452's Tools
    A nice application of an engineering design method/rule: Variation of material. Question yourself: Are the properties of the conventional material (steel) absolutely required? In this case:No. That opens a new playing field with new options, uses, etc. In this case (wood) the ease of making a jig allows special versions for cylinders, double rows, other stamp sizes, mixed sizes, quick and dirty or one-off solutions. I like it.
