Wood pallet assembly jig.
Reclaiming pallet wood - GIF
Pallet disassembly machine - GIF
Pallet flipper - GIF
1958 Japanese pallet crate securing clips - GIF
Forklift pallet rotator - GIF
jackhoying (Nov 22, 2023), nova_robotics (Nov 22, 2023)
He keeps doing it over and over, but the pile never gets any higher...
It is amazing how much really nice wood is used in pallets. I picked up 10 nice pallets with almost clear face plywood on the top side. I got 10 pieces of nice 1/2" x 40" x 48" plywood. there are some nail holes, but they were not too difficult to get apart.
I thought it was some type of devils gun that drove those nearly impossible to remove nails. That looked like some normal coil gun. If houses were built with those nails, I doubt that hurricane ties would be needed in windy areas. Years ago I built a tool out of a trailer screw jack for taking pallets apart that has gotten quite a bit of use.
When I had a marina and boat dock building company, I used ring shank nails where construction didn't require screws the ring shank nails had a tremendous amount of pull-out resistance in the softer treated woods twisted nails held better in hard wood and didn't have the tendency to bend as bad. when using a hammer to drive nails in common construction even smooth nails will hold better if the carpenter can drive and sink them in the fewest amount of strikes A rule of thumb was set drive sink. or set then in a single blow drive and sink, especially if using cement coated nails to cause enough friction to melt the glue coating would create a better bond. All the more reason why nail guns are used whenever possible. In addition to their obvious speed nails will hold better when shot in with a gun. Try nailing a 2x4 to a steel pipe with a hammer. It will never happen but pickup a DX 350 and you can shoot the specially designed nail through 1/4" steel with a 27 cal. blank
