Here's a double hook I made to pull on the accelerator pump that was stuck down in the bore of a carburetor. It had been sitting for far too long and lots of corrosion to deal with.
Once I had the wire hook on the accelerator pump, then I was able to attach it to my slide hammer and pop it loose and pull it out.
Go to about 4:40 in the video if you want to skip ahead to just the hook part.
