Results 1 to 7 of 7
Thread: Wire brick cutter - GIF
  2. The Following 4 Users Say Thank You to Altair For This Useful Post:
    bob_3000 (May 22, 2023), nova_robotics (May 22, 2023), rlm98253 (May 22, 2023), that_other_guy (May 28, 2023)
    Sep 2018
    nova_robotics's Tools
    Does it cut the ends square? I feel like it doesn't.
    Supporting Member thevillageinn's Avatar
    Jul 2017
    thevillageinn's Tools
    It appears that the second op trims a sliver off the ends…at least a small sliver drops next to the tire.
  5. The Following 2 Users Say Thank You to thevillageinn For This Useful Post:
    nova_robotics (May 22, 2023), that_other_guy (May 28, 2023)
    Sep 2018
    Quote Originally Posted by thevillageinn View Post
    You are 100% correct. If they changed up the kinematics of that wire cutter they could have a square cut. They could eliminate a whole step and all of that waste. That's going to bother me.
    LOL, don't let it bother you too much as long as the clay has not been fired it is like cookie dough just wad it up and reroll it. Slicing off the sliver only insure that every brick is uniform that rotating guillotine wire is cutting reasonably true though.
    Sep 2018
    Yeah it's probably not a big deal. A bit of material drop probably isn't the end of the world. I don't do anything with firing pottery (which I'm guessing is similar?), but my girlfriend does so I have a bit of second hand experience. Reusing clay needs a bit of attention. You have to really mechanically work it to get all the air bubbles out. Sometimes they use a special "pug" mill to work the air out, or sometimes a vacuum pump. If there are any voids full of air or water it'll destroy the part during firing.
  9. #7
    Sep 2015
    Kansas
    The second op cuts it into 6 smaller bricks, plus the end(s).
