Results 1 to 10 of 16
Thread: Wire Bender
    Supporting Member kess's Avatar
    Dec 2015
    Thessaloniki Greece
    kess's Tools
    Wire Bender
    Wire Bender mini tool.
    Suitable for wire bends up to Ø4mm as well and sheet metal strips (steel, stainless steel, aluminum, brass, copper, tin can)
    by the addition of one small cylinder with internal dia 4mm over the shaft.
    Materials: one set M16 bolt/nut, a broken drill bit Ø4mm and a piece of flat bar 15x3mm.
    For bigger wire diameters is needed the use of a bigger size bolt/nut than M16 or 5/8".
    Bolt nut M16. Using an Ø3.5mm drill bit do a hole from side to side.
    Do at first a cut at the nut's center till the hole
    and then a second cut removing the half 1/3 of the nut.
    Cut the bolt at center till the hole.
    Mark the nest hole for the shaft.
    Use a file to clean up the letters and numbers.
    Use at first an Ø3.5mm drill bit and then an Ø4mm to make a nest hole with 15mm depth.
    Cut of from the broken Ø4mm drill bit the needed piece and then weld the handle at the nut.
    I have used a piece of brass and a piece of aluminum foil for threads protection.
    Some bends are available on my YouTube vid.
  2. The Following 11 Users Say Thank You to kess For This Useful Post:
    emu roo (Oct 12, 2022), hansgoudzwaard (Dec 22, 2019), high-side (Dec 17, 2019), Jon (Dec 13, 2019), nova_robotics (Oct 16, 2022), Okapi (Mar 27, 2020), old_toolmaker (Oct 8, 2023), PowerMk (Jan 29, 2020), Resident114 (May 28, 2023), shopandmath (Dec 13, 2019), thehomeengineer (Jan 27, 2020)
    Supporting Member shopandmath's Avatar
    Jun 2019
    Kitchener ON,CA,
    shopandmath's Tools
    Hi Kess
    this is a good post because any one could make this minus the welding
    but could just use a wrench
    this is also an easy tool to store
    good job
    Ray
  4. The Following User Says Thank You to shopandmath For This Useful Post:
    Thanks kess! We've added your Wire Bender to our Metalworking category,
    as well as to your builder page: kess's Homemade Tools. Your receipt:
    Dec 2015
    Thessaloniki Greece
    kess's Tools
    Quote Originally Posted by shopandmath View Post
    Hi Kess
    good job
    Ray
    Hi Ray,
    Thanks a lot.
    The wrench can do the job as well.
    But a num 24 wrench it is little bit heavy for this job if the bends are too many.
    So if someone can't do the weld then can ask help from a friend to do this job.
    Regards
    Bill
  8. The Following User Says Thank You to kess For This Useful Post:
    Resident114's Avatar
    Dec 2018
    Thanx for the great idea,Ive just made this device.The bolt diameter is 20mm,the pin is 5mm.It works wonderful!
  10. #6
    Dec 2015
    Thessaloniki Greece
    kess's Tools
    Hi Resident114,
    I'm glad that my post was helpful to you.
    Also if you have some photos you can upload them here.
    I don’t have any problem.
    I like to see how it's made a similar build from another person.
    Regards
    Bill
  11. The Following User Says Thank You to kess For This Useful Post:
    Resident114 (Dec 18, 2019)
  12. #7
    Dec 2018
    Sure!no problem.Ive painted the handle,so as soon as it"ll dry I"post the photo.
  13. #8
    Dec 2015
    Thessaloniki Greece
    kess's Tools
    Ok Thanks a lot.
  14. The Following User Says Thank You to kess For This Useful Post:
  15. #9
    Aug 2016
    wizard69's Tools
    That is one nice bender! Simple too build but effective, can’t beat that.
  16. The Following User Says Thank You to wizard69 For This Useful Post:
  17. #10
    Dec 2015
    Thessaloniki Greece
    kess's Tools
    Quote Originally Posted by wizard69 View Post
    Hi wizard69,
    Thanks a lot.
  18. The Following User Says Thank You to kess For This Useful Post:
