Results 1 to 1 of 1
Thread: What's Inside A DPDT 2P2T 6 Pin Microswitch (4K)
    Supporting Member tsbrownie's Avatar
    Feb 2019
    tsbrownie's Tools
    In case you are restoring something with a DPDT 2P2T switch. I tore one apart to see how it was made and the quality of it.
    I can not tell by visual inspection what this failed. The switch became intermittent. Seems the contacts wore, corroded, or became loose. The new switch fixed it.
    The old switch was a DIP package that was modified to be surface mounted, so I did the same.
  2. The Following User Says Thank You to tsbrownie For This Useful Post:
    nova_robotics (Dec 18, 2021)
