Thread: What is a grinding dummy block?
    Supporting Member shopandmath's Avatar
    Jun 2019
    Kitchener ON,CA,
    shopandmath's Tools
    The "dummy Block" helps to prevent "grinding dry with fluid" by. Guiding fluid to the height of the workpiece before wheel contact is made.
    This style of dummy block is not to be confused with a dummy block used for plunge or creep feed grinder we do not actually cut into our dummy blocks when we're using them to control the flow of coolant too our work piece
    Example of grinding without using a dummy block
  2. The Following 3 Users Say Thank You to shopandmath For This Useful Post:
    albertq (Mar 23, 2024), piper184 (Mar 27, 2024), Ralphxyz (Mar 23, 2024)
    Aug 2021
    Cape Town SA
    albertq's Tools
    Thanks for that very useful tip.
