Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
Thread: Welding Pulse Monitor
    Supporting Member chy_farm's Avatar
    Apr 2018
    Yokohama, Japan
    chy_farm's Tools
    Hi FEM2008, thank you for words. Glad to know you have been somewhat linked to the excellent manufacturer!
    Chy
  2. #12
    Sep 2018
    Groningen, NL
    Carnel's Tools
    OK, Chy-Farm, your "old analogue welder" is already a more sophisticated electronic device. Now I can better understand your post. Thank you for your explanation.
  3. The Following User Says Thank You to Carnel For This Useful Post:
    chy_farm (Jul 30, 2020)
  4. #13
    Apr 2018
    Yokohama, Japan
    chy_farm's Tools
    A small tip about an oscilloscope that I need in this.
    Some of you may feel it's too costly to buy an oscilloscope for a sort of small job like this, namely to see the wave forms of your welding. Then I think I can recommend a cheapest one like the one I use on another tool I posted here;
    (Variable Frequency Drive for a larger factory fan)
    I got this (the one you see at the upper part of my VFD) new but it still does not cost too much, nearly $40 or less.
    Oscilloscope for this welder-purpose does not require too big features. We want it to see only very low frequencies like 1Hz to 1kHz (this means it's not pricey though), but one thing we need is that it must have a 'Hold Button' to keep the view when you want to stop its detection.
    Chy
  5. The Following 2 Users Say Thank You to chy_farm For This Useful Post:
    Carnel (Jul 31, 2020), that_other_guy (Oct 18, 2022)
  6. #14
    Quote Originally Posted by chy_farm View Post
    Chy
    Probably the cheapest oscilloscope is software on a laptop which plots the input on the microphone jack. Unfortunately the frequency response would probably not extent down to the 1 Hz range.
    Other cheap options include Arduino (and similar micros) based scopes, either stand alone with a dedicated TFT screen or even cheaper using a laptop for display and signal processing.
    There are many examples of how-to on the net.
    A big step up the food chain are oscilloscope boxes that connect to a laptop. I use a "Picoscope" which start from around USD 120+ and go up to $1000s. These are full featured scopes but with the advantage over dedicated scopes that the software has more processing power available from the PC.
  7. #15
    Apr 2018
    Yokohama, Japan
    chy_farm's Tools
    Showing a sample of usage for this tool in my another thread below;
    Adding Digital Generators to an Old Analogue TIG Welder
    in which I used a comparison data of this;
    Hope this can help your welding.
    Chy
  8. The Following User Says Thank You to chy_farm For This Useful Post:
  9. #16
    Feb 2018
    Could you just post the make/model of your welder?
  10. #17
    Apr 2018
    Yokohama, Japan
    chy_farm's Tools
    Quote Originally Posted by Tooler2 View Post
    Good evening Tooler, if you mean you want to see my old welder the set-up, see this pls;
    Chy
  11. The Following User Says Thank You to chy_farm For This Useful Post:
  12. #18
    Feb 2018
    I would prefer a link to the manufacture's page describing the welder, or a make/model that I can google search.
  13. #19
    Apr 2018
    Yokohama, Japan
    chy_farm's Tools
    Good morning Tooler, they do not have a site for this old welder made in early/mid 90's.
    Instead I have a copy of the manual here, posting a couple of meaning page out of it. Try read them with your good imagination!
  14. The Following User Says Thank You to chy_farm For This Useful Post:
