Results 1 to 10 of 20
Thread: WELDING FAILS!
    Supporting Member machining 4 all's Avatar
    May 2020
    machining 4 all's Tools
    WELDING FAILS!
    Today I put a smile on your face!
  2. The Following 9 Users Say Thank You to machining 4 all For This Useful Post:
    EnginePaul (Jan 8, 2021), Jon (Jan 9, 2021), madmick77 (Jan 9, 2021), Philip Davies (Jan 10, 2021), Scotty1 (Jan 8, 2021), Slim-123 (Jan 10, 2021), sossol (Jan 8, 2021), TheElderBrother (Jan 8, 2021), Tonyg (Jan 11, 2021)
    Lake Tahoe
    IntheGroove's Tools
    At first glance I thought I read Wedding Fails. The only wedding fail is "I do." Anyway, if you are going to weld a skeg on an outdrive, remove it from the boat and drain the oil...
  4. The Following User Says Thank You to IntheGroove For This Useful Post:
    NortonDommi (Jan 9, 2021)
    meyer77's Avatar
    Feb 2019
    I was on a job once and the guy installing a hand made metal hand rail was welding without a helmet (he did have one with him). I said "Don't you have a helmet?"
    He said "yea but I'm use to it"!
    May 2020
    "I'm used to it" is a bad excuse to go blind ... The arc emits visible and invisible light radiation, in practically all wavelengths! So, just use a suitable mask, to get a minimum protection, and no lame excuses...
    Lake Tahoe
    IntheGroove's Tools
    I got flash burn once. Once...
    May 2020
    Eyes burned by welding look like a cart full of sand...
  9. The Following User Says Thank You to machining 4 all For This Useful Post:
  10. #7
    meyer77's Avatar
    Feb 2019
    Quote Originally Posted by machining 4 all View Post
    He was a little odd to begin with, I was setting marble on the first floor, he was welding above me dropping sparks and slag onto the new marble!
  11. #8
    May 2020
    Unfortunately this is not the profile of a good professional! All coating and finishing must be protected from welding spatter...
  12. #9
    Aug 2012
    Australia
    desbromilow's Tools
    just me, or does the person pulling the Tig welder helmet off in #8 seem like the "fail" should be horseplay in the work place?
    Whilst the welder didn't have screens up, he was using his hand for a wind block, and was wearing correct PPE - signage should have been enough for observers to be protected - but some numbnut lifting my helmet whilst I'm welding would be considered as horseplay or worse.
  13. #10
    Jun 2019
    #1 no farting!!!
    Admittedly Have set fire to the cuff of my work pants. Saw this reflection inside my viser. From an early age my father taught me to wear welding gloves . "Its not to protect your hands son, its to put out the fire when u set yourself alight".
  14. The Following User Says Thank You to jatt For This Useful Post:
    that_other_guy (Jan 17, 2021)
