Thread: Welder at work on an offshore installation - GIF
    tooly (Jan 5, 2023)
    Supporting Member schuylergrace's Avatar
    Sep 2020
    Mesa, Arizona
    I wonder what position that is in the professional welder's certification practical test. I've got to say (on the twentieth viewing) he doesn't look uncomfortable, though!
    For topical application, only. Not to be taken internally or used in com-
    bination with other drugs or alcohol, except as directed by your shaman.
    Do not operate heavy equipment, unless you actually know how to.
    You have to be qualified for limited access, used to be called the Arkansas Bell hole. You had to section in a 6" pipe nipple on a horizontal 12" pipe 6 inches from a wall and 6inches down from the ceiling, root hot pass and cap were all done uphill. It is almost impossible to do unless you can weld with either hand Most righthanded pipeline welders will fail the first 6 times they try to take the test
  5. The Following 3 Users Say Thank You to Frank S For This Useful Post:
    rdarrylb (Jan 6, 2023), schuylergrace (Jan 6, 2023), Scotty1 (Jan 6, 2023)
