Thread: weld positioning fixture
    I need to weld the pivot tubes on to the I beams that I cut the profile into which requires them to be centered square and parallel in all 3 planes xyz
    doing this once would simply mean measuring and squaring it to do this on opposite ends gets a little more involved but to do this repeatedly becomes a time consuming chore
    So after trueing a single tube and tack welding it it place I built a fixture which will work on either end
  2. The Following 2 Users Say Thank You to Frank S For This Useful Post:
    luvmygto (Oct 8, 2021), mwmkravchenko (Oct 8, 2021)
    Thanks Frank S! We've added your Weld Positioning Fixture to our Welding category,
