Weir or low head dam effect on river topography demonstrated.
Geology stream table - GIF
Dam breach in China - GIF
Flushing silt from a dam - GIF
Dam spill gate failure - GIF
Lake Berryessa Glory Hole spillway drain - GIF
durrelltn (Jul 22, 2022), EnginePaul (Jul 21, 2022), mwmkravchenko (Jul 21, 2022), nova_robotics (Jul 21, 2022), Ralphxyz (Jul 24, 2022), Toolmaker51 (Jul 21, 2022)
Not so effective in milling machines or lathes running steel, better in non-ferrous or plastics, but weirs are used exactly this way in coolant tanks, especially big rotary Blanchard and reciprocal grinders. Typically there are 3 'locks', flat panels stepped in height; some use one drawing from below against flotsam debris.
A dream come true for every new shop-hand. . .
Last edited by Toolmaker51; Jul 21, 2022 at 01:22 PM. Reason: 4th times the charm (one extra to make sure)
Learned as much machining possible, as quickly possible for same reason. First shop had big Blanchards and Thompsons; had to be 50 gallons plus. Water soluble fluid was mixed by a venturi drawing from barrel of concentrate. Not high on list of enjoyable tasks. Rotary grinders were used prepping compression molds; big surface area, always both sides, very flat but not much concern about specific thickness. Lots of goo in the tank.
Rikk (Jul 25, 2022)
