Thread: Way To Repair Broken Housings, Cases, etc.
    Supporting Member tsbrownie's Avatar
    Feb 2019
    tsbrownie's Tools
    A fast, easy and very strong way to fix/patch/strengthen broken plastic housings, cases, boxes, enclosures, etc. Just need epoxy and cloth strips or fiber tape. With fast set epoxy you can finish a repair in 1-1.5 hours when time is critical. Produces a fiberglass-like result.
    Works well on almost anything that epoxy will stick to: plastics, bakelite, metals, etc.
    MATERIALS:
    - Epoxy (fast or slow dry per video)
    - Cloth strips or fiber tape
    - Hand protection (rubber gloves or plastic bags)
    - Sandpaper (for surface prep)
  2. The Following 12 Users Say Thank You to tsbrownie For This Useful Post:
    baja (Aug 13, 2019), bron9270 (Apr 25, 2023), DIYer (Aug 12, 2019), high-side (Aug 13, 2019), Jon (Aug 15, 2019), oldpastit (Aug 19, 2019), rlm98253 (Aug 12, 2019), Seedtick (Aug 12, 2019), Tonyg (Aug 13, 2019), tuchie (Sep 28, 2023), Tule (Aug 19, 2019), Whiteboardwarriors2 (Aug 18, 2019)
    Thanks tsbrownie! We've added your Plastic Housing Repair Method to our Fastening category,
    as well as to your builder page: tsbrownie's Homemade Tools. Your receipt:
    oldpastit (Aug 19, 2019), tsbrownie (Apr 25, 2023)
    Aug 2020
    glue
    <div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="http://www.homemadetools.net/homemade-plastic-housing-repair-method"> <img src="/uploads/225726/homemade-plastic-housing-repair-method.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="http://www.homemadetools.net/homemade-plastic-housing-repair-method">Plastic Housing Repair Method</a> <span> by <a href="http://www.homemadetools.net/builder/tsbrownie_3">tsbrownie</a></span> </div> <div class="tags">tags: <a href='http://www.homemadetools.net/tag/glue'>glue</a>, <a href='http://www.homemadetools.net/tag/repair'>repair</a> </div> </div> </div> </div>
    Ummmmm... CA glue, AKA super glue.
