Results 1 to 1 of 1
Thread: Water Flow Meter / Sensor- RPi 20 - YF-S201 Hall Effect
    Supporting Member tsbrownie's Avatar
    Feb 2019
    tsbrownie's Tools
    An intelligent water meter that can be used to control multiple functions (valves, detectors, warnings, logging...).
    An RPi experiment using the YF-S201 flow meter. Good for measuring and controlling water flows - home watering use, irrigation water use tracking, livestock water tanks, etc.
    Line 37: print('Time (min & clock) ', minutes, '\t', time.asctime(time.localtime(time.time())),'\n')
    The sensor is inline and uses an impeller with an embedded magnet. The magnet triggers a Hall effect switch sending a pulse at each revolution.
    There are 3 wires, red (power, 2-24 volts, but I've gotten it to work at 3 volts), black (ground) and yellow (Hall effect output).
    From the spec sheet:
    16 Hz = 2 L/min = 120 L/hr
    32.5 Hz = 4 L/min = 240 L/hr
    49.3 Hz = 6 L/min = 360 L/hr
    65.5 Hz = 8 L/min = 480 L/hr
    82 Hz = 10 L/min = 600 L/hr
    etc. Max 30 L/min
    Frequency (Hz) = 7.5 * Flow rate (L/min)
    Pulses per Liter: 450
    Model: YF-S201
    Sensor Type: Hall effect
    Working Voltage: 3.5 to 24V DC (min tested voltage 3.3V)
    Max current draw: 15mA @ 5volts
    Output Type: 5volt TTL
    Working Flow Rate: 1 to 30 Liters/Minute
    Accuracy: ±10%
    Maximum water pressure: 2.0 MPa
    Operating Temperature: ≤80℃
    Liquid Temperature: ≤120℃
    Output duty cycle: 50% ±10%
    Output rise time: 0.04us
    Output fall time: 0.18us
    Min Durability: 300,000 cycles
    Cable length: 15cm
    1/2" nominal pipe connections, 0.78" outer diameter, 1/2" of thread
    Size: 2.5" x 1.4" x 1.4"
    Notes: I found that when the impeller stops with the Hall effect switch triggered, it keeps sending pules to the RPi. Seems to be a Pi triggering issue per the internet.
    YOU NEED A VOLTAGE DIVIDER WHEN OPERATING ABOVE 3.3 VOLTS!!!
    MATERIALS
    - Raspberry Pi (and Pi power supply)
    - Breadboard
    - YF-S201 Water meter / sensor
    - Jumpers
    WARNING: Warning: mis-wiring or mis-programming your Pi or miswiring of accessories can ruin the Pi and accessories.
    Information/drawings offered as is. Use at your own risk. If you don't know, learn first.
  2. The Following 2 Users Say Thank You to tsbrownie For This Useful Post:
    mwmkravchenko (Sep 23, 2019), Whiteboardwarriors2 (Sep 25, 2019)
