Results 1 to 5 of 5
Thread: Wall-mounted can crusher - GIF
    Wall-mounted can crusher.
    Two-way can crusher - GIF
    Mini steam traction engine can crusher
    Car crusher - GIF
  2. The Following 6 Users Say Thank You to Altair For This Useful Post:
    baja (May 17, 2020), clydeman (May 16, 2020), Rangi (Feb 25, 2021), Scotsman Hosie (May 21, 2020), Seedtick (May 16, 2020), Tule (May 17, 2020)
    jdurand's Tools
    Needs a way to keep your hand out when actuated AND needs some vent holes in the plunger, you can see the air bursting out to the side.
  4. The Following User Says Thank You to jdurand For This Useful Post:
    mr herb (May 17, 2020)
    Sep 2013
    Karl_H's Tools
    We need that couple from Finland to put some full ones in there!
    Hydraulic Press Channel
    https://www.youtube.com/channel/UCcM...6_1Hwi5-MeiQgw
  6. The Following User Says Thank You to Karl_H For This Useful Post:
    PDXsparky's Avatar
    Nov 2018
    Can't return the can for deposit redemption if it gets crushed like that.
    earz's Avatar
    May 2014
    earz's Tools
    Not sure that air is bursting out the side. It appears there’s a little air hole in the back of the crusher tube that pushes the crushed can out. I think the remaining liquid from one one the cans is what you see getting blown by that ejection jet.
