Results 1 to 7 of 7
Thread: Vibrating concrete screed - GIF
    Floradawg (Jun 20, 2021), mwmkravchenko (Jun 20, 2021), nova_robotics (Jun 19, 2021)
    Marion, Iowa
    metric_taper's Tools
    Is this a gas powered weed wacker with an eccentric spinning weight? The power head is hidden by his coat and belly.
  4. The Following 2 Users Say Thank You to metric_taper For This Useful Post:
    Sep 2018
    nova_robotics's Tools
    I think you nailed it. That's exactly what it looks like.
    Also there's way too much water in that mix.
  6. The Following User Says Thank You to nova_robotics For This Useful Post:
    Apr 2014
    Gadgeteer's Tools
    What is the result/consequence of too much water?
    Sep 2018
    Quote Originally Posted by Gadgeteer View Post
    Everything gets worse. Lower strength. All the aggregate settles out to the bottom. Prone to cracking. I think it screws up aeration too (which is super important with concrete). Just generally results in junk. A soupy mess like that is the mark of a bad contractor.
    The ideal concrete mix, for maximum strength, is so dry you'd probably never want to use it. You have to add a bit more water than that just for it to be workable. And paradoxically once it sets up you want to keep the concrete as wet as possible while it cures. Concrete is weird.
  9. The Following 3 Users Say Thank You to nova_robotics For This Useful Post:
    Gadgeteer (Jun 20, 2021), milla (Jun 26, 2021), mwmkravchenko (Jun 20, 2021)
  10. #6
    In the very beginning of the video you can see the gas tank of the power head
    Agreed there is way too much water in the mix, I've seen thicker mixes come out of a pumper hose
  11. The Following 2 Users Say Thank You to Frank S For This Useful Post:
  12. #7
    Perth Ontario Canada
    Flow agent is your friend. Water your enemy. If you have the right flow agent is is super easy to work and yet will be as strong as it can be.
  13. The Following User Says Thank You to mwmkravchenko For This Useful Post:
    nova_robotics (Jun 21, 2021)
