Results 1 to 5 of 5
Thread: A Very Smooth Slide and Lock Mechanism
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    I recently built a device that had a rod that must smoothly slide yet firmly locks in place. Since I rarely throw anything away, a scrap of a Dr. Scholl's shoe insert saved the day.
    https://rick.sparber.org/SlideAndLock.pdf
    Thanks,
    Rick
    Rick
  2. The Following 6 Users Say Thank You to rgsparber For This Useful Post:
    baja (May 25, 2019), high-side (May 25, 2019), Jon (May 30, 2019), Scotsman Hosie (May 25, 2019), Seedtick (May 24, 2019), Toolmaker51 (May 26, 2019)
    jdurand's Tools
    On my mill I put a small puck of Delrin under the screws that lock the dials for X-Y-Z. I also changed out the grub screws for simple socket head cap screws and just make them finger tight. That was probably 15-20 years ago and I haven't changed them since.
    I have no idea why they put grub screws in the dials as you have to reset them all the time (well, until I got a DRO). The Delrin works well enough for this, not the silicone grease drag you were looking for but enough so the dial can be lightly tightened and hold position.
  4. The Following 3 Users Say Thank You to jdurand For This Useful Post:
    rgsparber (May 24, 2019), Scotsman Hosie (May 25, 2019), Toolmaker51 (May 26, 2019)
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    Thanks for the great idea! I have the same problem on my lathe and you have furnished the ideal solution.
    Rick
    Rick
    Thanks rgsparber! We've added your Slide and Lock Mechanism to our Miscellaneous category,
    Oct 2012
    Rick
    Very nice fix for a problem I believe we all have had at one time or another. I have thrown many of the cut off pieces, I will put the next ones in the shop junk draw.
    Good job.
    Nelson
