Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
Thread: Very easy surface rust remover for chrome
    Charron63's Avatar
    Oct 2017
    Tidewater VA
    I believe its the phosforic acid that actually kills the rust. I use it diluted in my shop to remove flash rust, also evaporust etc may be using it not sure but don't go using it bare handed it will damage the paws something horrible
  2. The Following 2 Users Say Thank You to Charron63 For This Useful Post:
    FEM2008 (Jun 27, 2020), Toolmaker51 (Nov 30, 2017)
  3. #12
    Jan 2018
    Dbj58's Tools
    I use it on my old motorcycle and it works great. The foil is soft so it does not damage the crome it seems to remove the bumps and fill the gaps and the acid in the coke helps remove rust
    Berkshire UK
    thehomeengineer's Tools
    Thank you for this great post. will be giving this a go.
    Many thanks again
    The Home Engineer
  5. #14
    Nov 2019
    Iv'e used Milk Stone Remover (cattle item found in many farm and tractor outlet stores) for this and it works very well also.
  6. #15
    Jul 2019
    Ohio, USA
    Yep, Coke has phosphoric acid, same as Naval jelly and evapoprust. You can also get phosphoric acid at beer and wine making suppliers.
  7. #16
    May 2014
    one thing that Coke has is phosphoric acid as well as the carbonation from CO2.
    I would think that the aluminum is acting as a mild abrasive. Aluminum metal quickly oxidizes to aluminum oxide when exposed to air.
