Results 1 to 10 of 13
Thread: Variable power supply
    Aug 2016
    Has anyone made a variable power supply for use in home electroplating ?
  2. #2
    Feb 2015
    Manitoba Man's Tools
    Swiss Toni
    Depending on the power needed a cheap dimmer switch ahead of a car battery charger works to provide adjustable power to hot wire foam cutter or
    a electro chemical rust removal system for me. The latter is similar to electro-plating but in reverse.
    Bob
  3. The Following 2 Users Say Thank You to Manitoba Man For This Useful Post:
    C-Bag (Aug 6, 2016), Mike Walton (Aug 14, 2016)
    Aug 2016
    Thanks Bob. Food for thought!
    May 2016
    Don42's Tools
    It depends on how much current you need. Plating is best done with a current-regulated supply (not voltage-regulated). It is relatively simple to build a current regulator if you have any experience with electronics. Email me for more info.
    Another good solution is to just buy a switchmode bench supply from EBay. Some are well under $100, and most of them are capable of regulating both voltage and current.
    Mike Walton's Avatar
    Jul 2015
    Mike Walton's Tools
    i would concur with using a battery charger or transformer and a resistor.
    the plating process doesn't take much voltage, but the more amps available will enhance deposition rates.
    Where there is a Will, there is a Way!
    markevans36301's Avatar
    Oct 2012
    markevans36301's Tools
    I'm not an electroplating expert by any stretch but I do know electronics enough to agree with Don that if you arn't an expert the best route is to find, buy, adapt. It is a rare day when reinventing the wheel is the best route with electronics.
    Figure out just exactly what your needs are and then let google and other search engines be your friend. Very good chance Ebay will have just what you are looking for.
  8. #7
    Jan 2015
    variable power supply for electroplating
    Quote Originally Posted by Swiss Toni View Post
    What metal do you plan to electroplate? Do you know how many DC amps are required to electroplate with it?
    I ask because the cost of equipment is directly proportional to the number of plating amps needed.
  9. #8
    Toni I don't know what finish you are looking for but I've used products from these folks in the past with great results
    EPI - Electrochemical Products Inc.
    For my power supply though I had re-purposed a 650 Amp DC power supply from a large mig welder. But we were doing 1000s of small parts contained in baskets every week
  10. #9
    evaskp's Avatar
    Nov 2015
    Löberöd, Sweden
    Do you know what voltage and how many amps you need?
    _________________________
    Krister Persson
  11. #10
    Aug 2016
    Guys, thanks very much for the informative replies! I will be plating (BZP) steel items for some of my motorcycle restorations. I think the best idea,as suggested, is to visit 'that site' and look for a purpose built unit, electrickery not being one of my strong points!
