Results 1 to 5 of 5
Thread: Variable Feed Speed Control for Mini-Lathe
    Supporting Member tmate3's Avatar
    Jan 2021
    tmate3's Tools
    A good while back I bought a Grizzly mini lathe, and like my old Atlas 6 incher, I had to switch the gears to adjust the feed rate. My solution for that is pictured below.
    I center drilled the lead screw with a 5/16" drill, then drilled and tapped a setscrew hole an inch or so from its end. I then made a female to male adaptor that slid into the end of the lead screw and fit on the shaft of a Grainger gearmotor. The male end of the adaptor had a flat milled into it. A drilled detent would have accomplished the same thing. I drilled and tapped a couple of holes in the end of the lathe and made a motor mounting bracket that bolted in place.
    A DC model railroad transformer controlled the feed rate in forward and reverse.
    Variable Feed Speed Control for Mini-Lathe-mini-lead-screw-drill.jpg Variable Feed Speed Control for Mini-Lathe-mini-tap-set-screw-hole.jpg Variable Feed Speed Control for Mini-Lathe-mini-lead-screw-mod.jpg Variable Feed Speed Control for Mini-Lathe-mini-finished.jpg
  2. The Following 4 Users Say Thank You to tmate3 For This Useful Post:
    bruce.desertrat (Jan 26, 2021), DuayneI (Jan 31, 2021), Duke_of_URL (Jan 31, 2021), Home-PC (Jan 27, 2021)
    Thanks tmate3! We've added your Mini Lathe Variable Speed Feed Control to our Lathe Accessories category,
    as well as to your builder page: tmate3's Homemade Tools. Your receipt:
    Jul 2019
    So, if you add a way to read RPM you "could" do rudimentary threading?
    Pretty cool idea. I have that same exact DC speed controller.
    Jan 2021
    tmate3's Tools
    Quote Originally Posted by cementtruck View Post
    I believe you would need a way to sync the spindle speed with the carriage movement.
    Jul 2019
    I guess a stepper motor moving the carriage and a hall effect sensor on the chuck end would be the only way to get that 99.98% to synch up. Back to the drawing board ... and the ELS forum (*sigh).
    Still a great project though if all you need is a quick way to get that carriage back and forth quickly.
