Results 11 to 20 of 21
Thread: Vacuum hold down fixture for cnc router.
    Thanks machiningfool! We've added your Vacuum Hold Down Fixture to our Workholding category,
    as well as to your builder page: machiningfool's Homemade Tools. Your receipt:
    Download plans for vacuum tables.
  2. The Following User Says Thank You to DIYer For This Useful Post:
    ncollar (Apr 22, 2018)
  3. #12
    Oct 2012
    Bob
    I think you did a very nice job and holding anything soft and possible of deforming or smashing with pressure requires a better way and you nailed it. Nice job and thanks for sharing
    Nelson
  4. #13
    Supporting Member machiningfool's Avatar
    Jul 2015
    Seffner Florida
    machiningfool's Tools
    Thank you very much. It does work as designed and I am surprised at the holding force. Bob.
  5. #14
    Dec 2016
    Ralphxyz's Tools
    Now I want to see it working or more so how you actually use it!!
    Ralph
  6. #15
    Jul 2015
    Seffner Florida
    Vacuum hold down.
    Ralph
    Ralph, if you have read all of the posts by me regarding the vacuum hold down, your questions will be answered. How I use it is, I cut a piece of plastic to fit the entire fixture and turn on the vacuum. It pulls 2 lbs. per square inch, so, 8" by 32" =256 sq. in. and 512 lbs. total pressure, enough to hold the plastic rigidly for cutting. I use a drag knife in my router and the cutter cuts almost through the plastic and I remove the parts by bending the plastic. The plastic is about .040 inches thick. Thanks for your interest. Bob.
  7. #16
    Dec 2016
    Ralphxyz's Tools
    Thanks Bob, " the cutter cuts almost through the plastic " was what I was wondering about and would like to see in action.
    I was picturing cutting all the way through and losing the vacuum as you moved along but almost through should retain the seal.
    Ralph
  8. #17
    Jul 2015
    Seffner Florida
    Answer
    Ralph
    Yes, that is where I thought you were going. No it doesn't cut through, for that reason. Bob. No vacuum this time.
    link to Youtube
  9. #18
    Supporting Member bimmer1980's Avatar
    Jan 2018
    bimmer1980's Tools
    Bob, Nice job on the vacuum table.
    Most commercial CNC routers use a vacuum table. Your's is a good example of how to build one for a home use environment. thanks for posting.
  10. #19
    Jul 2015
    Seffner Florida
    Thank you very much for your attention. Robert Brown.
  11. #20
    May 2014
    Vacuum box dimension question
    Quote Originally Posted by machiningfool View Post
    I have a need to cut .040 styrene plastic on my cnc router and divised this simple but effective vacuum hold down fixture, works well. Bob.
    Very nice project but I have to ask why you made the vacuum chamber so large?
