In my video I demonstrate how I used a carbide round over router bit to shape an aluminum rod by holding it in a boring bar quick change holder:
I'm still exploring speeds and feed rates with these bits!
Andyt (May 11, 2022), baja (May 15, 2022), bruce.desertrat (May 10, 2022), durrelltn (May 11, 2022), EnginePaul (May 12, 2022), Jon (May 16, 2022), mwmkravchenko (May 10, 2022), NortonDommi (May 16, 2022), nova_robotics (May 15, 2022)
yes, as a an experienced woodworker, I use all my woodworking machines on aluminum routinely. chop saw, table saw, router, etc. I don't use WD-40 on those machines so I don't contaminate my wood though. As you could see in my video though I was using a lot of WD-40 on that router bit. I'm still not sure what speed to use, so I was running around 1500 RPM but some people said I should go much slower, since it's not the way the bit was designed to be used it's hard to figure out speeds and feeds. Since the bit is not spinning and there's a lot of surface contact, my intuition said spin the lathe fast.
I routinely use these form cutters on a milling machine, mainly for edge rounding on aluminium, and I run the same speeds and feeds that I do with other carbide milling cutters. Although with the larger tools like the one in the video I cut the feed down. Mine have 1/4" shanks and I broke a couple due to a high feed rate. On one like yours I welded a 1/2" shank and now I can run at normal carbide bit feeds for the tool diameter and number of cutting edges.
Feeds are less of an issue with the likely use on a lathe but I would run at the usual RPM for carbide tools on the workpiece diameter. Most lathes do not spin fast enough for small diameter work pieces. Chatter may require modifying the best speed for cutting. 1/4" shanks are a limiting factor for chatter.
Guy Marsden (May 11, 2022)
"Do or do not, there is no try" - Yoda
nova_robotics (May 16, 2022)
