Results 1 to 10 of 12
Thread: Using a magnet to remove scrap from a railroad track - GIF
    nova_robotics (Jan 10, 2025), Ralphxyz (Jan 17, 2025)
    hemmjo's Tools
    So, all of those bent wire things in the hopper were picked up from along the tracks?
    Sep 2013
    Karl_H's Tools
    Looks to me that "those bent wire things" were just replaced with the green "wire things." They pulled the old ones and just left them on the ground, then put in the new ones. Now they are finishing things up by collecting the old ones.
  5. The Following User Says Thank You to Karl_H For This Useful Post:
    hemmjo's Tools
    Now you have made me wonder what are those bent things for? I have walked a lot of railroad track in my near 76 years. Have never seen anything like that.
    Of course I freely admit, LOTS of things I have never seen before. Maybe next week I can see all the rest..
  7. The Following User Says Thank You to hemmjo For This Useful Post:
    that_other_guy (Jan 17, 2025)
    Aug 2012
    Australia
    desbromilow's Tools
    I know them (the clips) as "Pandrol" clips. They are essentially springs which engage in the base (part of the sleeper) and press down on the top of the rail flange. The clip is essentially a spring, so it uses the elastic properties of the spring to restrain the rail in poistion. The Rail could have a plastic saddle piece between the sleeper and the rail flange, and the pandrol clip can also have a plastic piece between it and the rail flange - the plastic pieces essentially insulate the metal rail from the sleeper - this is important for certain track occupancy detection systems
    Track maintenance work I recently observed had some of the removed clips being reused, but not all. I was not in a position to ask what criteria was used to determine if a clip was reused (work gang had a tight timeframe to get the switch replaced.)
  9. The Following User Says Thank You to desbromilow For This Useful Post:
    Karl_H (Jan 11, 2025)
  10. #6
    hemmjo's Tools
    Interesting. All I have ever seen used is the old style, iron railroad spike. All the rail lines around wher I am have been in use close to or over 100 years. Wefor sure need an upgrade here in the USA.
    Found this video. have to copy and paste the link. It will not post here. (or I can't make it work
  11. The Following User Says Thank You to hemmjo For This Useful Post:
  12. #7
    Supporting Member thevillageinn's Avatar
    Jul 2017
    thevillageinn's Tools
    Various spring type clips or bolts are used primarily for concrete ties/sleepers where the spikes are common for wood.
  13. #8
    Elizabeth Greene's Tools
    I still see the old-style railroad spikes used too, for wooden crossbeams. They hold down a metal plate and the metal plate holds the rail to the plate with these clips.
  14. #9
    Aug 2018
    that_other_guy's Tools
    are all the iron ore nuggets I see along railway lines not high enough grade to be picked up?
    Brian
  15. #10
    Aug 2012
    Australia
    desbromilow's Tools
    Quote Originally Posted by that_other_guy View Post
    Brian
    iron ore needs to be about 86% iron before a tramp metal magnet can attract it enough to pick it out of an orestream. Typical "high grade" iron ore is only around 65-75% iron content (the rest being impurities like silica, alumina, etc). Tramp metal magnet usually sits about 400-500mm (15-20") above the bottom of the belt trough, with an ore depth of around 300-350 mm (12-14") at the peak. Tramp metal magnets are designed to collect metal in the orestream such as excavator teeth, fire-extinguishers, or other "bits of metal" which if left in the orestream will end up ripping conveyor belts, or jamming in crushers, etc doing expensive and unsafe damage.
There are currently 8 users browsing this thread. (0 members and 8 guests)
