Results 1 to 5 of 5
Thread: Using an electric screwdriver
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    This is one of those times when I feel like I must be the last person on earth to know this trick.
    My Ryobi electric screwdriver looks like a drill. I install a flat-bladed hex body bit in the magnetic chuck. The slot in the screw is never aligned with the blade of the screwdriver blade. Sometimes I can twist my wrist a little to get them to match. Most of the time I pull the trigger for a moment and see if the blade is in a better alignment. I almost never win this bet.
    What I failed to notice is that there is 90 degrees of backlash in the chuck. I can rotate the bit a total of 90 degrees with my fingers. This will be enough to always get the desired alignment.
    Rick
    Rick
  2. The Following User Says Thank You to rgsparber For This Useful Post:
    Philip Davies (Nov 10, 2023)
    Dec 2015
    Reading, Berks, UK
    Philip Davies's Tools
    I did not know that. The only slot screws I use are brass, and are inserted with a cabinet screwdriver. I often dismantle furniture which contain slot screws and I save them if they’re an unusual size. But for ordinary purpose I think torx are best. Mostly I use salvaged cross head screws and if they are Phillips then the bit in the drill is pozi and if the screw is pozi then the bit is Phillips.
    I certainly never knew that ! It sounded like a neat trick but when I examined my two Black & Decker drivers I discovered they had no perceptible backlash.
    Since electric drivers usually have a planetary drive system, I wouldn't expect them to have much backlash.
    This is bad. Now you have me wishing for a tool that's sloppier than the one I have. :-(
    I still want to crucify (with #16 slotted screws) the guy who invented slotted screws. Oh, and Henry Ford, too - the guy who rejected Robertson screws in favor of the evil Phillips nightmare.
  5. The Following 2 Users Say Thank You to mklotz For This Useful Post:
    Frank S (Nov 10, 2023), rgsparber (Nov 11, 2023)
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    I don't think it would be hard to build a chuck with built in 90 degree backlash. Ya got me thinking...
    Rick
    Rick
    Rick
    Perhaps your time would be better spent building a furnace to melt all slotted screws into an unrecognizable lump of slag unfit to serve even as a door stop. :-)
