Results 1 to 10 of 11
Thread: Using a dull drill bit as welding filler rod - video
    Using a dull drill bit as welding filler rod. 5:21 video:
  2. The Following 15 Users Say Thank You to Jon For This Useful Post:
    baja (Jan 3, 2021), byates (Jan 3, 2021), desbromilow (Dec 29, 2020), Dragonhand (Jan 2, 2021), jimfols (Dec 28, 2020), Keithm (Dec 28, 2020), marksbug (Dec 29, 2020), MsLizVt (Jan 4, 2021), mwmkravchenko (Dec 29, 2020), odd one (Dec 28, 2020), Philip Davies (Jan 3, 2021), Priemsy (Jan 2, 2021), Ralphxyz (Jan 2, 2021), sacco1 (Dec 28, 2020), trevor_60_r (Jan 6, 2021)
    Sep 2015
    Ontario Calif USA
    All of his videos I've watched are first rate.
    Jim
    Apr 2016
    awesome!!!
    jdurand's Tools
    I guess small diameter drill rod/silver steel could also be used.
    Feb 2019
    I saw someone do this using cheap (dollar store grade) needle files as a poor man's hard facing rod on some sort of tool, may have been a small hammer of some sort. Sam idea and reportedly worked well enough for the application at hand. Lots of options if you use your imagination I guess.
    Supporting Member elk-a-holic's Avatar
    Jan 2016
    Concrete nails?
  8. The Following User Says Thank You to elk-a-holic For This Useful Post:
  9. #7
    Supporting Member trevor_60_r's Avatar
    Nov 2019
    Queensland, Australia
    trevor_60_r's Tools
    I have been a Boilermaker for 40 years and have been looking fore something as a filler for hard-facing with Tig. I will give it a go,
    Thanks very much for the informed Video. I just had never thought of using a drill.
  10. #8
    Apr 2016
    I wish i could weld up some camshafts and have reground for roller lifters....among other things.
  11. #9
    Nov 2019
    trevor_60_r's Tools
    marksbug - Camshafts are usually made out of one of the grades of Cast iron, not something easily welded.
  12. #10
    olderdan's Tools
    Allen Millyards video shows how
    welds camshafts for his specials.
  13. The Following User Says Thank You to olderdan For This Useful Post:
    trevor_60_r (Jan 10, 2021)
