Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
Thread: Unsafe pulley belt installation - GIF
    Quote Originally Posted by desbromilow View Post
    looks like he sets the belts up in the palm of his hand, then presents his palm to the pulley, keeping his fingers lower than the palm - similar to how you feed apples to a horse. - it looks dangerous (and yes I'd use a chicken stick or switch everything off), but I suspect some thought has gone into doing this "safely"
    I'm favoring desbromilow's analysis. The thought of "doing this safely" is under least potential risk. There may have been reason the motor couldn't have been shut down; not anywhere OSHA has a presence.
  2. #12
    Supporting Member Beserkleyboy's Avatar
    Aug 2014
    Beserkleyboy's Tools
    Frank,
    You're quite right there...but mostly to untrained thoughtless users. I started on a 10" Delta Unisaw at 14, now operating a 12"/3hp Wadkin clone for the last 30 years (I'm 69 now...) AND I've still got all 10...but seriously, very sharp blades and the knowledge of what's being cut and how to feed it and the sound of the cut will keep you on the 'right' side of safe...and I paint the table insert red so the brain automatically knows it's the danger zone. Now those pesky angle grinders, can't live with them or without them! I've seen WAY to many homemade 'attachments' for them that are flat out dangerous, particularly putting saw blades rated up to 6000 rpm, when the grinder goes to 11,000! On a recent stay in the ED at hospital, I asked an ambo about tradie accidents and he said, far and away the most common, was hand held circular saw cuts to arms and legs. Stay safe, even just for Mrs Frank! Cheers
    Jim - Sth Coast NSW soon to be Hunter Valley
    olderdan's Tools
    That is extremely dangerous
    In my early teens I worked at a local brickworks which had 6inch flat belt fast and loose pulleys below floor level. There was a one armed man who worked in a shed making hand made bricks (no pun intended) who I leaned had tried to remount a belt with the pulleys running, it tore his arm of at the shoulder. I tried make conversation with him to no avail as it affected him badly. At least the company kept him in employment.
  4. The Following User Says Thank You to olderdan For This Useful Post:
    mr mikey (Aug 21, 2022)
  5. #14
    Supporting Member mr mikey's Avatar
    May 2022
    Michigan
    mr mikey's Tools
    That was common in machine shops, farming and pretty much any industry that had belts running everywhere. My mom worked in Greenfield Village here in Dearborn Mi., It was created by Henry Ford. He had restored buildings and showed how early America was built. Thomas Edison and many more are displayed here. It had a running machine shop with a steam engine that ran all the equipment with belts that ran from the ceiling pulleys and shafts to the machines. A worker giving a demonstration got caught in the belt. Sadly, he did not make it. Mr Mikey.
  6. #15
    Mar 2018
    This guy's lucky he didn't knock himself out when his hand hit his face coming off of that belt!
    "This country was founded by a bunch of slave owners that told us all men are created equal..." - George Carlin
