Thread: Unit conversion without a calculator
    The ability to convert approximately back and forth between inferial and metric is a worth-while talent to cultivate. Here are a couple of tricks that allow you to do it mentally. Handy when you lack a calculator or want to do a mental check that you keyed the correct numbers into one.
    CONVERTING FRACTIONAL MEASUREMENTS TO METRIC
    Keep doubling numerator and denominator until denominator is 256
    5/16 = 5*16 / 16*16 = 80/256
    Now we need to multiply by 25.4 (mm/inch) to convert to millimeters. But 25.4 = 254/10, so
    80/256 * 254/10 = 80/10 * 254/256
    254 is close enough to 256 to make the approximation that 254/256 ~= 1 and we have
    5/16" ~= 80/10 = 8 mm [exact value = 7.94 mm]
    So the rule is DOUBLE NUMERATOR AND DENOMINATOR UNTIL LATTER IS 256, THEN ANSWER IS NUMERATOR WITH DECIMAL SHIFTED ONE PLACE TO LEFT.
    CONVERTING METRIC MEASUREMENTS TO INFERIAL INCHES
    We need to divide by 25.4
    8 mm / 25.4
    but 25.4 can be approximated as 25 and written as 100/4. Then...
    8 / 25.4 ~= 8 * 4 /100 = 32/100 = 0.32" [exact value = 0.315]
    So the rule is MULTIPLY BY 4 AND MOVE DECIMAL TWO PLACES TO LEFT.
  2. The Following 5 Users Say Thank You to mklotz For This Useful Post:
    byates (Jun 5, 2023), Francis4344 (May 18, 2023), RetiredFAE (May 17, 2023), rlm98253 (May 17, 2023), uv8452 (May 18, 2023)
    Elizabeth Greene's Tools
    For temperature measurements, this is head-doable math.
    C to F
    Double it
    Take away 10%
    Add 32.
    So 20c is 20x2=40. 10% is 4, 40-4=36+32=68F.
    F to C
    Take away 32
    Add 10%
    Half it.
    68F - 32 = 36. 10% of that is about 4, so 36+4 = 40. Half that is 20C.
  4. The Following 4 Users Say Thank You to Elizabeth Greene For This Useful Post:
    byates (Jun 5, 2023), cogentia (May 18, 2023), RetiredFAE (May 17, 2023), schatten (Jun 1, 2023)
