Results 1 to 8 of 8
Thread: Unimat Lathe Boring Bar Holder
    May 2014
    Del Mar, California
    Paul Jones's Tools
    Unimat lathe boring bar holder was machined from 6061-T6 aluminum and designed to hold 0.5” diameter boring bars. The T6 temper is a very strong and a good choice for tooling for the 3” swing lathe. This particular size holder allows using more tooling from my other lathes. The various clamping screws are 8-32 stainless steel socket head screws. Also the center clamping screw allows aligning boring bars made with flats for setting their alignment.
    Attached Thumbnails Attached Thumbnails Unimat Lathe Boring Bar Holder-unimat-boring-bar-holder.jpg   Unimat Lathe Boring Bar Holder-top-view-unimat-boring-bar-holder.jpg   Unimat Lathe Boring Bar Holder-unimat-0.5-inch-boring-bar-holder.jpg   Unimat Lathe Boring Bar Holder-detail-unimat-0.5-inch-boring-tool-holder.jpg
  2. The Following 6 Users Say Thank You to Paul Jones For This Useful Post:
    Captainleeward (Apr 12, 2015), IAMSatisfied (Apr 1, 2018), Karl_H (Dec 5, 2019), kbalch (Apr 13, 2015), olderdan (Oct 23, 2017), Scotthendo (Nov 2, 2017)
    Jul 2014
    San DIEGO, California
    Captainleeward's Tools
    Quality work and great design to. :O)
  4. The Following User Says Thank You to Captainleeward For This Useful Post:
    Paul Jones (Apr 12, 2015)
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Thanks Paul! I've added your Boring Bar Holder to our Tool Holders category, as well as to your builder page: Paul Jones' Homemade Tools. Your receipt:
    Very nice work, Paul Jones!
  7. The Following User Says Thank You to DIYer For This Useful Post:
    Paul Jones (Apr 16, 2015)
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    This thread has been moved to the Must Read subforum. Congrats (and thanks) to Paul for making such a valuable contribution!
    Oct 2012
    Paul
    As usual you have done a fascinating job. I've always loved the versatility of the Unimat Lathe and Milling Machines. So much can be done with them. Very nice machining and write up.
  10. The Following User Says Thank You to ncollar For This Useful Post:
    Paul Jones (Oct 22, 2017)
  11. #7
    May 2014
    Del Mar, California
    Paul Jones's Tools
    ncollar,
    Thank you for the responding to this posting. I enjoy using the 3" swing Unimat for some of my small, precision work. Below are some additional photos about making the boring bar holder.
    Machining the boring bar through hole to be parallel with the lathe axis.
    I used the Unimat milling head to cut the boring bar compression slot using a slotting saw blade. The Unimat face plate in the background of the photo is used as a reference to set the parts at 90 degrees before starting the slotting cut.
    Unimat Lathe Boring Bar Holder-cutting-compression-slot-boring-bar-holder.jpg
    It is a fun small lathe for many projects where appropriate.
    Regards,
    Paul Jones
  12. #8
    olderdan's Tools
    Paul that is a super job, to my shame I have never considered the Unimat to be anything more than a light hobby machine.
    Watching your many posts on the work you do with it now makes me wish I had one.
    Regards
    Olderdan
  13. The Following User Says Thank You to olderdan For This Useful Post:
    Paul Jones (Oct 25, 2017)
