Results 1 to 8 of 8
Thread: Twin Tri-Pacer custom side-by-side double engined Tri-Pacer - photo
    Twin Tri-Pacer custom side-by-side double engined Tri-Pacer. Largest image size available.
    Also known as the Wagner Twin 2, Wagner Twin Tri-Pacer, and Wagner Pacer 125, this was a standard PA-22 fitted with two 125 hp Lycoming O-290-D engines mounted side-by-side. The conversion was produced in three weeks by Harold Wagner from Portland, Oregon. To clear the two overlapping propellers the left engine shaft was fitted with a 4.75 in (121 mm) extension. After 100 hours testing, the aircraft was converted back to its original configuration.
    Casting a giant propellor GIF
    Propeller feathering - GIF
  2. The Following 7 Users Say Thank You to Jon For This Useful Post:
    baja (Sep 3, 2019), clydeman (Nov 22, 2024), Rangi (Sep 3, 2019), rdarrylb (Nov 23, 2024), Scotsman Hosie (Sep 11, 2019), Seedtick (Sep 2, 2019), volodar (Sep 4, 2019)
    Supporting Member IAMSatisfied's Avatar
    Apr 2017
    The desolate ranch country of Northeastern corner of New Mexico, USA
    IAMSatisfied's Tools
    Those props obviously have to be counter-rotating... I wonder what they used to keep them in sync. (chain, belt or direct gear drive?). It sure doesn't appear like there's much clearance between the tip of the propeller and the adjacent hub.
    Edit: If I would have paid attention, I'd have noticed the pitch of the propellers were identical.
    Dec 2017
    baja's Tools
    Quote Originally Posted by IAMSatisfied View Post
    https://1000aircraftphotos.com/Contr...David/8788.htm
  5. The Following 2 Users Say Thank You to baja For This Useful Post:
    IAMSatisfied (Sep 3, 2019), Rangi (Sep 3, 2019)
    Apr 2017
    Thank you for that... I didn't even consider the possibility of adding an extension to one prop shaft... it certainly does the job.
    Jan 2016
    Southern tip of Vancouver Island
    I would assume the two Lycomings are identical, as are the props. Not counter rotating. No need for any mechanical synching. Spacer puts props on separate planes. RPM synch is as in any simple twin; two hand throttles and pilotīs ears to minimize beats.
    Jan 2016
    We would assume the two Lycomings to be identical, same for props. So not counter rotating. And no need for any mechanical synching. Spacer puts props on separate planes. RPM sync is as in any simple twin - two hand throttles and pilotīs ears minimize any beats.
  9. #7
    Supporting Member Scotsman Hosie's Avatar
    Apr 2017
    Salt Lake City, UTAH
    Scotsman Hosie's Tools
    What a weird looking hack for a Tri-pacer. Surprised it had enough wing – and heavy enough airframe – to support it, let alone the increase in stall speed.
  10. #8
    Jan 2016
    Quote Originally Posted by Scotsman Hosie View Post
    Good points. Not clear whether the 100h testing included flight type(s), and with what results. Several other types Here:
    TwinNavion.com
  11. The Following 2 Users Say Thank You to volodar For This Useful Post:
    Jon (Sep 14, 2019), Scotsman Hosie (Sep 17, 2019)
