Results 1 to 5 of 5
Thread: Turning a Brake ROTOR on a Small Lathe Mill Drill
    Supporting Member theeddies's Avatar
    Mar 2019
    Georgia, US
    theeddies's Tools
  2. The Following 2 Users Say Thank You to theeddies For This Useful Post:
    nightride (Oct 7, 2020), sossol (Oct 8, 2020)
    Oct 2017
    i bought a used one of these lathe/mills about 10 years ago,f 100$ ,, yeah i stole it, but it didnt have a 3 jaw chuck,, anyway,, when u have sparks your machines RPM is just too high, i can see that in the first minute,, u just have to change pulleys and slow it way down,,better too slow than too fast,,not a job shop here,,make sure u have a good size radius on your cutting tool,even those cheap brazed one will work if u do that, the cmmg an such,,inserts already have a big radius,,cast iron is very abrasive and will dull cutting tools faster than u think they will, check cutting edge after every cut,,other wise u might have to stop in the middle of a cut to resharpen your cutting edge,dont want to do that on a finish cut!!
  4. The Following User Says Thank You to madokie For This Useful Post:
    theeddies (Oct 6, 2020)
    Mar 2019
    Georgia, US
    theeddies's Tools
    Thanks! Unfortunately this particular machine's lowest speed for the lathe is 500 rpm. I am looking into a few options to address that in the future.
    olderdan's Tools
    Years ago I did reface brake discs on an old Hillman Hunter that I was running on a shoestring, more an act of desperation. I used raising blocks of the headstock to get the swing and it worked well enough to pass the MOT test.
  7. The Following User Says Thank You to olderdan For This Useful Post:
    Mar 2019
    Georgia, US
    theeddies's Tools
    You raised the headstock? That is a dedication/desperation to saving money, I like it. Thanks for sharing!
    Eddie
