Results 1 to 4 of 4
Thread: Tube inner sanding shaft
    Jul 2014
    France, Brittany !
    Christophe Mineau's Tools
    This days, I am in the mood of making woodwind musical instruments.
    Once the bore hase been reamed, or after the tone holes have been drilled, you may need to smoothen the bore.
    This tool is called a "mouche" in French (means a fly), this is a very old trick, to hold a piece of rigid sand paper at the end of a shaft, powered by an electric drill
    Cheers !
    Christophe
    Facebook : La Belle Note
  2. The Following 12 Users Say Thank You to Christophe Mineau For This Useful Post:
    Andyt (Apr 11, 2018), baja (Dec 21, 2019), Captainleeward (Nov 20, 2015), johnsmachines (Aug 6, 2024), Jon (Nov 17, 2015), kbalch (Nov 17, 2015), mwmkravchenko (Apr 11, 2018), oldcaptainrusty (Apr 10, 2018), Paul Jones (Nov 18, 2015), PJs (Nov 17, 2015), rlm98253 (Nov 12, 2017), Toolmaker51 (Nov 12, 2017)
    Thanks Christophe! We've added your Bore Sanding Tool to our Sanding category, as well as to your builder page: ChristophePat's Homemade Tools. Your receipt:
    Dec 2015
    Hello Christophe Mineau,
    Thanks for the Project... I´ve been looking for a neat Project for something like yours... I´ve been using a piece of tube like you have, but i´m trying to get Creative for do something with handle and probably two bolts to secure the sanding paper...
    Regards,
    Sérgio P.
  5. The Following User Says Thank You to spereira For This Useful Post:
    Christophe Mineau (Dec 20, 2015)
    Quote Originally Posted by Christophe Mineau View Post
    This days, I am in the mood of making woodwind musical instruments. Once the bore hase been reamed, or after the tone holes have been drilled, you may need to smoothen the bore.
    This tool is called a "mouche" in French (means a fly), this is a very old trick, to hold a piece of rigid sand paper at the end of a shaft, powered by an electric drill.
    We have 'fly-paper' too; entirely different purpose, but puns don't often get work done.
    A split rod driving abrasive can be very effective. My results improve when sheet is tapered somewhat, rotating so narrow end is on the outside, blending the surfaces.
    To other readers; these are notoriously out of balance! Insert paper to bore BEFORE rotating, or unintended things get involved.
    Like flinging safety glasses across the shop.
