Results 1 to 6 of 6
Thread: Trimming a roof ridge cap - GIF
    carloski (Nov 5, 2022), mwmkravchenko (Mar 26, 2022), Rangi (Nov 5, 2022)
    May 2015
    Tasmania, Australia
    Bony's Tools
    What's the point in trimming for the sake of 25mm. It was better left alone.
    Oct 2016
    old kodger's Tools
    Quote Originally Posted by Bony View Post
    Sorry bony, you got that one wrong, he's not "trimming" for the sake of 25mm, he's profiling the capping to fit the roof tin shape,AND IF YOU DON'T,WIND WILL BLOW WATER UP UNDER IT.
    May 2015
    Tasmania, Australia
    Bony's Tools
    Thanks old kodger, I'm obviously not a roofer !
    Most metal roofers just install corragated rubber under a cap without the turned down lip as the one in the video, because it is so much faster and costs much less than the labor to trim a turned down lip. IMO the trimmed edge gives it a more professional look. You can also buy caps fully shaped with the corrugations already there. Those are the most expensive and have a true blended finished appearance, also do the best job of sealing out wind and rain or insects
    Mar 2018
    If he goes back and seals that cap down it's the best way to do it (except maybe pre-cut corrugated caps). Almost no chance of weather infiltration. The only issue is, no way to vent at the cap. It's the age old problem with profiled roofing systems. When I worked for a ridge vent manufacturer, we told roofers to use foam self-adhesive seals with a board on top, then apply the ridge vent on top of that then cap it with a flat cap It works and allows venting at the ridge but then the ridge has a high profile.
    "This country was founded by a bunch of slave owners that told us all men are created equal..." - George Carlin
