Results 1 to 10 of 13
Thread: Trick - How to use Isolierband in a narrow place
    Supporting Member diyfixman's Avatar
    Jan 2019
    diyfixman's Tools
    I want to share with you a simple trick that I have been using for many years. This trick will help you wind an electrical wire in a narrow and crowded place where an Electrical tape cylinder cannot fit.
    Amazing Videos and DIY Guides, Explanations, Tips, Tricks and Much More...
    Facebook Page | YouTube channel
  2. The Following 40 Users Say Thank You to diyfixman For This Useful Post:
    asterix (Mar 9, 2021), baja (Mar 10, 2021), Beserkleyboy (Mar 9, 2021), Big-Pete (Mar 15, 2021), bills4-4-2 (Mar 10, 2021), carloski (Nov 27, 2022), clydeman (Mar 14, 2021), elk-a-holic (Mar 13, 2021), EnginePaul (Mar 10, 2021), Francis4344 (Mar 10, 2021), freddo4 (Mar 14, 2021), Geez (Mar 9, 2021), gumser (Mar 10, 2021), Home-PC (Mar 10, 2021), Inner (Mar 10, 2021), jackhoying (Mar 9, 2021), jimfols (Mar 9, 2021), jkahn (Mar 10, 2021), Jon (Mar 8, 2021), katy (Mar 9, 2021), Moldyjim (Mar 10, 2021), NortonDommi (Mar 10, 2021), nova_robotics (Mar 14, 2021), Ralphxyz (Mar 14, 2021), RetiredFAE (Mar 9, 2021), sacco1 (Mar 10, 2021), sask man (Mar 7, 2021), Skun Knuckles (Mar 10, 2021), Sleykin (Jul 14, 2021), tenncf (Aug 12, 2023), thehomeengineer (Mar 9, 2021), thevillageinn (Mar 14, 2021), toeless joe (Mar 9, 2021), Tooler2 (Apr 25, 2021), Toolmaker51 (Mar 9, 2021), tsbrownie (Mar 10, 2021), Tule (Mar 15, 2021), will52100 (Mar 14, 2021), wolfpaak (Mar 10, 2021), YOUCARS (Mar 16, 2021)
    GeoffN's Avatar
    Apr 2017
    Ipswich,Qld
    You just made my day, thank you: bananadance:
  4. The Following User Says Thank You to GeoffN For This Useful Post:
    diyfixman (Mar 10, 2021)
    Berkshire UK
    thehomeengineer's Tools
    So simple.
    Thank you for sharing
    The home engineer
  6. The Following User Says Thank You to thehomeengineer For This Useful Post:
    Supporting Member basil3w's Avatar
    Mar 2012
    The 'Why didn't I think of that' solutions are always the most valuable, Thanks!
  8. The Following 3 Users Say Thank You to basil3w For This Useful Post:
    diyfixman (Mar 10, 2021), EnginePaul (Mar 10, 2021), wolfpaak (Mar 10, 2021)
    Mar 2014
    Beaumont, TX
    Paul Alciatore's Tools
    That's a neat trick.
    I always use heat shrink tubing on splices like that.
    Paul A.
  10. The Following 2 Users Say Thank You to Paul Alciatore For This Useful Post:
    diyfixman (Mar 10, 2021), NortonDommi (Mar 10, 2021)
  11. #6
    Jan 2019
    diyfixman's Tools
    Thank you so much my friends, I'm glad you like it!
  12. #7
    hemmjo's Tools
    That is a good trick, been doing that for years when heat shrink cannot be used. It is also better to start the wrap in a spiral along the wire. You also have to be sure your fingers are not dirty or you ruin the stick on the tape, However, I suggest that you used better quality tape. I NEVER use tape if the manufacturers is not willing to print their name on it.
  13. The Following 2 Users Say Thank You to hemmjo For This Useful Post:
    diyfixman (Mar 10, 2021), Sleykin (Jul 14, 2021)
  14. #8
    Supporting Member Hans Pearson's Avatar
    Jan 2017
    Thanks for that very good solution. I am often in that situation and when a joint needs soldering heat shrink sleeving cannot be used.
  15. The Following User Says Thank You to Hans Pearson For This Useful Post:
  16. #9
    Sep 2018
    Great idea. Have used differing versions of this. If there is a remote chance of moisture getting in I use 3m self sealing tape.
  17. The Following User Says Thank You to mbshop For This Useful Post:
    diyfixman (Mar 17, 2021)
  18. #10
    Jun 2018
    Louisiana
    Well done sir, You da man
