Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 39
Thread: Tool Post Grinder
    Mar 2013
    Switzerland
    Okapi's Tools
    A good work, based on the idea used on Schaublin and others small lathes makers, but a lot less expensive.
    I have exactly the same construction for a Schaublin 70 with the improvement of the independent motor you've made.
  2. #12
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    One is glad to be of service, Doug. What I was initially impressed with was the 17.5 thou of radial clearance between the shaft and retaining washer to allow the shafts to be "carefully" installed in the housing/bearings and cleverly using a 9/16 UNF for the retainer on the pulley end. Again, Excellent design, IMHO. The design reminded me of T-nuts for 80/20 or Bosch extrusions. I assume I'm right about using Round Bar to start with. Thanks again for sharing all this! ~PJ
    Mark Twain
  3. #13
    May 2014
    Del Mar, California
    Paul Jones's Tools
    Doug,
    Thank you for your explanation for how you attached the spindle housing and still have the thickness of the retaining washer clear the spindle when the spindle is inserted.
    Paul
  4. #14
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Hi Doug,
    Thanks for another great contribution! Your Tool Post Grinder is the 'Tool of the Week'!
    As you've already received one of our official HomemadeTools.net T-shirts, we'd be glad to award you a $25 online gift card.
    Just send me your email address via PM and we'll get things processed directly.
    Congrats!
    Ken
  5. #15
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    Congrats Doug! Well deserved! ~PJ
    Mark Twain
  6. #16
    New plans added on 01/13/2025: Click here for 2,698 plans for homemade tools.
  7. The Following 3 Users Say Thank You to Jon For This Useful Post:
    Paul Jones (Feb 8, 2016), PJs (Jan 15, 2016), rossbotics (Dec 1, 2017)
  8. #17
    Feb 2015
    Manitoba Man's Tools
    From Canada
    Nicely done and documented. I am always looking for ways :-) and means.
    Bob
  9. #18
    Apr 2015
    Now I know what my next project will be. Really nice work and thanks for posting!
  10. #19
    WyoGreen's Avatar
    Very nice design, I've been thinking about building one for some time now. So I've been studying the drawings, and am a little confused about a couple of things. In looking at the Grinder Base drawing, I see the dimension between the two holes that attach the Base to the Spindle Housing to be 1.250", but the Spindle Housing drawing shows the dimension to be .750 inches. The second thing confusing me is the Spindle Housing drawing shows the Base attaching close to one end of the housing, yet the pictures appear to show the base attached to the middle of the housing. Since the motor specs show the motor to be about 6" long, I could see the motor having to be attached toward the front end in order for the pulleys to line up at the back end.
    Could there have been a design change between the drawings and the actual finished grinder? Is the spindle housing longer than 6 inches?
    I only bring this up in case someone builds this from the plans and things don't line up right.
    Thanks a lot for the design, it helps a lot in my thinking process, Steve
  11. The Following User Says Thank You to WyoGreen For This Useful Post:
    PJs (Mar 12, 2016)
  12. #20
    WyoGreen's Avatar
    Flat Belt
    Very nice design. What I'm most interested in however is a source of high speed flat belts. I went to the source you quoted for the flat belt, but only found variations of v belts. I have used poly belts, but they are too flexible for higher speeds. Could you give us a bit more information on the belt you used?
    Thanks, Steve
