Results 1 to 10 of 13
Thread: Tool Makers V-Blocks
    Dec 2013
    Florida
    rossbotics's Tools
    Over the weekend I was thinking about what tool I didn't have as far as machine shop tooling, On several occasions I have had the need for a pair of small V-Blocks just to fit the mill vise, I went to the steel rack where I keep my small pieces and found a piece of 4140 1.000" x 1.500" X 4.000", so I cut it in half and machined the blocks to the specs I wanted, I stamped the numeral 1 on one end of each block for a reference then oil hardened and tempered them, I cleaned them up and ground them together making a matched pair, I didn't take any manufacturing photos but took a few photos of the finished blocks and the cad drawing.
    As always thanks for looking and happy machining
    Doug
    Comments are always welcome
    Doug
  2. The Following 11 Users Say Thank You to rossbotics For This Useful Post:
    high-side (Jan 8, 2019), Home-PC (Jan 1, 2021), jjr2001 (Jan 7, 2019), LMMasterMariner (Jan 16, 2019), Metallurg33 (Jan 7, 2019), old_toolmaker (Jan 15, 2019), Paul Jones (Jan 13, 2019), PJs (Jan 9, 2019), Seedtick (Jan 7, 2019), Tule (Mar 22, 2019), zarembak (Jan 7, 2019)
    jjr2001's Tools
    Nice set of V-blocks Doug.
    I like the mounting holes which my small set does not have. Makes mounting on a tooling plate easy.
    Cheers, JR
  4. The Following User Says Thank You to jjr2001 For This Useful Post:
    PJs (Jan 9, 2019)
    When I have made pairs of things like V-blocks I do not cut them in half at the beginning. I make a cut on each face less than or equal to 1/4 of the material thickness. Then I do the grinding with it as a single piece. When finished I cut through and face off the ends.
  6. The Following 2 Users Say Thank You to tonyfoale For This Useful Post:
    jjr2001 (Jan 8, 2019), uv8452 (Mar 9, 2023)
    Dec 2013
    Florida
    rossbotics's Tools
    Well it's fine to make them in one piece as long as your not using hardened steel.
    Doug
  8. The Following 2 Users Say Thank You to rossbotics For This Useful Post:
    jjr2001 (Jan 8, 2019), PJs (Jan 9, 2019)
    Quote Originally Posted by rossbotics View Post
    Doug,
    You have lost me there. I have done it with hardened steel, what problem do you see?
  10. #6
    Dec 2013
    Florida
    rossbotics's Tools
    Doug,
    Tony I understand what you're saying about how you would have done something like this, and I don't see anything wrong with your approach, I guess thats just the difference between two different tool makers.
    Cheers
    Doug
    Doug
  11. The Following User Says Thank You to rossbotics For This Useful Post:
    PJs (Jan 9, 2019)
  12. #7
    Cheers
    Doug
    Of course.
    My initial post was not meant as a "mine is better than yours" approach.
    Considering the time difference you must be an early riser.
  13. #8
    Dec 2013
    Florida
    rossbotics's Tools
    Of course.
    No intent taken Tony,
    I retired this past March and I'm really having a hard time adjusting to the "nothing to do world" but I'm learning, after working all your life it's hard to just sit on your azz and do nothing, I wake up at some weird hours sometimes but I'm adjusting, you can only work so long in the shop and you get tired of it too.
    Cheers
    Doug
    Doug
  14. The Following User Says Thank You to rossbotics For This Useful Post:
    PJs (Jan 9, 2019)
  15. #9
    I retired this past March............... but I'm adjusting, you can only work so long in the shop and you get tired of it too.
    Doug
    I will only be 75 in a couple of months so I am still too young to feel the effects of a full day in the workshop. I feel unsettled if I am not there.
  16. The Following User Says Thank You to tonyfoale For This Useful Post:
    olderdan (Jan 8, 2019)
  17. #10
    Aug 2016
    wizard69's Tools
    First nice work on the Vee blocks! I like seeing all the different approaches to what is a very basic tool in the shop
    It is kind of funny but I just pulled apart some fixturing at work that has a bunch of Vee blocks (well chucks of steel passable as such). I like the idea of found materials being leveraged in the shop
    Cheers
    Doug
    This is what bothers me more than anything about a pending retirement. I really think I will need to find part time work or maybe set up a small business of some sort. I'm 58 and I'd like to leave ASAP but the idea of not having something to focus on is unsettling to say the least.
