Results 1 to 1 of 1
Thread: The toilet steam engine
    To introduce kids to the idea of steam as a means of doing work and as a tribute to Heron of Alexandria, I built this spinner engine from a toilet tank float. The top with the two jets unscrews so the float can be partially filled with water. Then a propane torch applied to the bottom of the float gets the thing spinning nicely on its fishing tackle "bearing".
    If you build one, be sure to solder the float seam - DAMHIKT. Also think about adding a bearing at the bottom of the float lest it wobble excessively while operating.
  2. The Following 9 Users Say Thank You to mklotz For This Useful Post:
    Altair (Oct 26, 2020), baja (Nov 29, 2020), HobieDave (Jan 21, 2021), jjr2001 (Apr 23, 2017), Karl_H (Nov 23, 2020), kbalch (Sep 4, 2015), KustomsbyKent (Apr 24, 2017), Paul Jones (Nov 21, 2015), the artfull-codger (Sep 21, 2015)
