Thread: tire zip ties for traction
    wldrbob's Avatar
    Feb 2015
    manitoba canada
    i saw them on youtube and thought id tell you what i have used for years a light piece of chain and a steel carabiner and a piece of wire feed the wire through the spoke in your rim pull the chain around the tire and hook up the carabiner i sometimes use only one on a tire but mostly put 3 on each drive tire..easy to hook up and easy to take off once your out of the snowbank or mudhole ..25 bucks for the chain and the carabiners and reusable 15 bucks for the zip grips and not reusable cheaper than a tow but i will stick with my cheep chains
  2. The Following User Says Thank You to wldrbob For This Useful Post:
    Paul Jones (Jul 13, 2015)
    Apr 2013
    Neat idea, and a quick set up for the occasional need. Well done!
    Diapers and politicians need to be changed often...and for the same reason!
