Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
Thread: TIG Pedal build
    Perth Ontario Canada
    Quote Originally Posted by Charst View Post
    Hi!
    How's your Shrinker-Stretcher doing? Is it already in operation?
    My tip is that the filament will be the first thing conk out. We shall see...
    At the moment it works just fine.
    Charst
    I am getting my shop all setup and moved into a new building. Nothing happening yet. But I am planning for sure to make your shrinker stretcher! I will post pics. Probably over the winter.
  2. #12
    Congratulations Charst - your TIG Pedal is the Homemade Tool of the Week!
    We had a lot of high-rated tools this week, but this one stood out for being a heavy-duty, comprehensive, and low-buck solution.
    T-Nuts by ttmrj
    Hammer Head Inserts by Philip Davies
    Machinist's Level by Claudio HG
    Tubing Bender by big o
    Adjustable Vise Hold Downs by jjr2001
    Workshop Crane by Kwandotechnic
    Mill Vise by machining 4 all
    Mini Table Saw by morsa
    Audible Continuity Tester by mklotz
    Tire Lift by big o
    Belt Grinder by bouboulas
    Folding Table by fawabros
    Filler Rod Storage Tubes by Charst
    Magnetic Indicator Holder by olderdan
    Portable Light by RCTURKA
    Hose Clamp Tool by Mr.DK DIY
    Planing Stop by natie123
    Sheetmetal Alignment Clamp by Tuomas
    Camera Slider by Es Welding
    Jar Opener by orioncons36
    Depth Gauge by Christofix
    Charst - you'll be receiving a $25 online gift card, in your choice of Amazon, PayPal, or bitcoin. Please PM me your current email address and gift card choice and I'll get it sent over right away.
    This is your 2nd Homemade Tool of the Week win. Here are both of your Homemade Tool of the Week winning tools. Congrats again
  3. #13
    Aug 2012
    Australia
    desbromilow's Tools
    So is that a multiturn potentiometer? Looking at the path of the cable/string, it looks like you'd get at least 1 - 1/5 turn easily, or is it a trick of the camera angle?
    for the benefit of someone who does not own a TIG yet, it the pedal just for current control? or an "on/off" (gas) as well?
    thanks,
    Des
  4. #14
    Supporting Member Charst's Avatar
    Jan 2018
    Charst's Tools
    Quote Originally Posted by desbromilow View Post
    thanks,
    Des
    Hi Des
    with the pedal you have both functions: When pressing it slightly down the microswitch releases the arc start, gas, etc. By pushing it further down you increase the amperage up to the value that you have preset on your welder.
    And no, the potentiometers can only be turned abt. 270°. I just wrapped the string several times around the shaft to have as much friction as possible. The friction is even increased by the spring loaded lever on the other end. The string actually moves 50mm when the pedal is pushed down which gives abt. 3/4 rotation on the 20mm shaft.
    Cheers
    Charst
  5. #15
    Aug 2012
    Australia
    desbromilow's Tools
    Hi Des
    Cheers
    Charst
    Thanks Charst for the explanation!!!!!!
  6. #16
    Mar 2018
    Your connector fabrication is ingenious!
