Results 1 to 5 of 5
Thread: Thin material drilling technique - GIF
  2. The Following 9 Users Say Thank You to Altair For This Useful Post:
    BuffaloJohn (Aug 10, 2023), garage nut (Aug 10, 2023), Inner (Aug 10, 2023), nova_robotics (Aug 10, 2023), odd one (Aug 10, 2023), Ralphxyz (Aug 16, 2023), rlm98253 (Aug 10, 2023), tuchie (Aug 10, 2023), verticalmurph (Aug 11, 2023)
    Aug 2019
    Oregon, USA
    BuffaloJohn's Tools
    I have heard of this trick before, nice video shows just how well it works!
    Aug 2012
    Australia
    desbromilow's Tools
    would like to have seen the LHS hole drilled completely through, OR seen the RHS hole stopped partially to compare the results. I've also heard of this trick, but by not comparing apples with apples, it's failed to show why you would use the trick.
    That said, I've nearly moved to the use of cone drills (aka step drills, or pagoda drills) for holes between 5mm and 35mm in thin material these days.
  5. The Following User Says Thank You to desbromilow For This Useful Post:
    Christophe Mineau (Aug 11, 2023)
    Jul 2019
    I'd say that "trick" wasn't needed because the material wasn't exactly thin!
    Apr 2016
    Buffalo, NY
    I have heard of using an oily rag to do that.
